The first time I burnt an SVCD from a bin & cue, I used a 16x burn speed.
When watching this disc, there is a noticeable horizontal shaking of the picture.
I have since read somewhere that when burning SVCDs you should keep the burn speed low, certainly below 12x, because high speeds can cause video problems.
I no longer have the bin/cue files on my hard disc, so I basically have 3 questions:
- how can I make a bin and cue pair from the disc?
- will the files be exactly the same as the original bin/cue I used to make the disc, or will the high burn speed (and the lack of error correction in the SVCD format) have altered them slightly?
- once I have the files back, can I use VCDEasy to extract the mpeg2 data and VideoLAN to play the movie, so I can see if the "shaking" was present in the original encode?
Results 1 to 1 of 1
How to Burn at 16 speed or better with 4 burners
By burn master in forum User guidesReplies: 9Last Post: 30th Mar 2010, 20:49 -
Dual Layer Burn Speed
By webstar in forum MacReplies: 8Last Post: 17th Sep 2009, 01:37 -
burn speed for videos
By gameroftheuk in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2008, 12:51 -
I need 'burn speed over ride'
By theewizard in forum DVD & Blu-ray WritersReplies: 15Last Post: 13th Jun 2007, 00:25 -
What Speed should I burn DVDs?
By Sudden Impact in forum Newbie / General discussionsReplies: 6Last Post: 9th May 2007, 07:11
