What's happening here? I'm using Vobrator to demux a VOB with DTS soundtrack and when it does a straight demux - .m2v and .dts files the .dts file plays fine in powerdvd. However attempting to select PCM output creates a WAV file that not even Powerdvd plays correctly. It is just white noise.
Recording via line in on soundcard is not desisred since I need to re-mux this thing to SVCD. BTW I don't have an AC3 track in the vob. It's those DTS trailer vobs.
I tried graphedit but there was not DTS input plugin and I don't have the LIGOS plugin for dts input.
Thanks in advance for your help.
Results 1 to 1 of 1
How do you convert DTS to PCM
By ChrisDaMan in forum AudioReplies: 27Last Post: 29th Jan 2013, 03:32 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 09:40 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
