I can't find any program that will edit the MPEG2 files generated by this card (which won't produce a file larger than 2GB, despite an alleged registry hack on the Hauppauge site). I have tried every MPEG editor available with exactly the same results - either the file is not recognized as valid, or there are audiosync problems.
So, is there any program that will recognize this USB device so that I can capture to AVI, edit, then encode to mpeg2? I have tried:
Pinnacle Studio
Premiere 6.5
Videowave 5
Thanks!
Regards
Colin Gavin -
hi
there is one, Nero - but does an all in one burn from almost anything to the mpeg required for VCD. so there's no intermediate avi, if that's what you're after -
Hello
Many thanks for that info. Yes, it's the AVI I need!
Best wishes
Colin GavinRegards
Colin Gavin -
clefmusic:
A bit late but maybe still useful:
I use a card (not USB) and mine may be a little later than yours.
You can set cap size to somewhere around 4.444G (I can, anyway)
Womble MPEG-VCR 3.14 does an excellent job cutting and joining and does read the Hauppauge version of MPEG. Having standardized the MPEG, you can use a MPEG-AVI converter.
I wish there was a half decent program for the Nova-T though. The Hauppauge software is REALLY bad. -
I had the card too (rather than the USB), and I can certainly agree with one thing:
I found it produced completely non-compliant MPEG streams, and even worse it kept dropping the audio during capture every time the stream changed a little (i.e. during advert breaks etc..) and never recovering it again.Originally Posted by jaapcr
It wasn't even very good for watching tele, let alone capturing.
But... then we got burgled; so it's someone else's problem now
I never found anything that could capture from the card except the bundled software.
I don't know if the USB Nova-T is the same, but the PCI card I had was installed in the device manager as a network interface - which meant it had problems with firewalls etc.. too.
Maybe this is one of the reasons absolutely nothing else could use it as a capture source.
Sorry - not much help!
cheers,
mcdruid.
How would you all rate this japanese USB capture device ?
By MidnightMike in forum Capturing and VCRReplies: 12Last Post: 20th Jul 2009, 23:29 -
A Good USB Capture Device?
By hech54 in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2007, 03:23 -
USB device capture
By ramin in forum Capturing and VCRReplies: 1Last Post: 15th Nov 2007, 15:48 -
capture device: usb or pci?
By danica in forum Capturing and VCRReplies: 2Last Post: 5th Sep 2007, 13:04 -
USB Capture Device
By gruberted in forum Capturing and VCRReplies: 13Last Post: 11th Jul 2007, 14:56
