I have an ati aiw radeon card (which i have just bought)
when i record using the digital vcr theres a problem when i play the clip back after 30sec or so it frezzes in between two frames but the sound carrys on. this happens no matter what setting i use mpeg2,mepeg1 etc
has this happend to anyone???
thanks in advance
kilika
This (might) be caused by a Macrovision (copy protection) signal. The ATI drivers (and maybe the board hardware itself) is set to react in this manner when it comes across Macrovision.
Don't try any driver patches you may find, none of them really work. Your best best is a video patch-in, patch-out box going into your composite... really the only way I'm aware of that should eliminate the signal. -
this also happens when i record of the tv thats why i didn't think it was a copy right problem. also the video i was recording was one of my own with programs recorded on it
any more info would be great
kilika -
TV as in the internal tuner?... hmmm...
Do you have digital cable/satelite? I've heard rumors that some (only some) companies and channels are actually adding macrovision signals to the broadcast... but maybe just a rumor...
maybe try the ATI patch and see how it goes, just for the heck of it... it's somewhere on doom9.net's page...
I do know that for me, it was overly sensitive with that "feature" that caused the frame loops. It may take drastic meastures. -
i have an ATI TV Wonder card. I am running my satelite through it with no problem. the only capture program i am useing is the mmc7 from ATI's website. only problem i've come across is captureing at two high of a bit rate. if your thinking of useing the patch for disableing the macrovision, good luck, if you get it to work possibly post here how you did it. i couldn't get it to work.......
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
