  1. Hi everyone !
    If i rip a DVD to SVCD ( MPEG2) can i cut MPEG2 file be a part, like Episodes ??
    =-VNPN=-
  2. Member adam's Avatar
    Sep 2000
    http://www.vcdhelp.com/edit
    There are several guides for cutting mpeg2 files on this page.
    If you use a separate mpg for each episode, or chapter, or whatever..then there will be a noticable pause in between each. If you would prefer seamless playback but still be able to jump from one set point to another, then use entrypoint chapters. I recommend you use VCDEasy for authoring your SVCDs as it makes it very easy to add entrypoint chapters.
  3. Thanks alot for your info. :P
    =-VNPN=-
