I have a Sony DVP-NS315 which cannot play SVCD's unless it is converted to simple multiplex (details here: http://www.geocities.com/newestmoviesencode/dvdvcd )
My problem is this: I have an SVCD in bin/cue format that i wish to convert. Whats the simplest way to do this? Is there any way to do this without ripping the SVCD then converting, then creating again?
simply download the free program IsoBuster, and use it to extract the mpeg file from the image file. However, I tried that method once. It didn't work for me. Let me know if you get it to work, please.
right after i posted, i thought of basically that, i'm trying it now, I'll let you know
so far so good, TMPGEnc converted it fine, now I just need Nero to burn it then I'll try it
ok, when I imported into Nero, it complained about not being compliant
part of this was the resolution which is 480x480, its supposed to be normal ratio (4:3 or whatever) but I assumed the DVD player would read it differently (you'll have to excuse me, I'm still pretty new at this)
Anyway, I told Nero to ignore and burn anyway but it said it won't fit on a CD. I read in another post that [S]VCD's are burned in type-2 which can hold up to 800 meg, the movie is only 786 meg.
Any help anyone? -
I guess you are using Nero Express. It forces you to re-encode the Mpeg2 file to Mpeg1 since you compiling a standard VCD. Only, Nero Burning Rom will allow you choose either re-encode or ignore this. Try the over-burn option if the file is too big. good luck!
Program for simple editing and burning
By hodocka in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2011, 23:16 -
Simple Editing
By JJ Bones in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2010, 17:08 -
Simple wmv editing tool
By karebo in forum EditingReplies: 2Last Post: 5th Apr 2010, 05:40 -
simple editing program
By devdev in forum EditingReplies: 6Last Post: 4th Jun 2009, 08:40 -
Sony Vegas Users? Simple editing question...
By jnaizer in forum EditingReplies: 12Last Post: 25th Oct 2008, 17:07
