I have both on my computer and I can't seem to copy it. I tried a disc copy with toast and it only burnt 18 out of the 31 chapters and I got an authorization error. I also tried to copy the files on to my hard drive but it said all the files couldn't be copied a -32 error. What should I try next?
I just tried using toast again using a save as disc image. The image is on my hard drive but I stll keep getting an authorization error after I burn the DVD-R. What else can I try? Please, I'm new to this and I'm getting really frustrated and loseing lots of $ on dvd-r's. By the way I am copying a DVD-R and it is under 4gb so that isn't the problem.
If this is a commercially pressed DVD, try using DVD Backup (http://195.134.134.27/downloads/macdvd/DVDBackup_13.bin) to copy the VIDEO_TS folder to the hard drive, and then use Toast in DVD mode to burn a new DVD containing that folder.
note: this will only work if the total contents of the DVD < 4.4 GB. -
jchansen Posted: Jan 04 21:21
This is a DVDR that you made, and its not CSSed, right?
Yeah I too have a problem copying a dvd-r that I made thats not CSSed. I tried dvdbackup and 0sex and it just ends up erroring out.
Burning an iMovie to DVD without having iDVD
By bradelway in forum MacReplies: 3Last Post: 30th Nov 2009, 11:39 -
Toast vs. iMovie/iDVD which is better for Mac?
By HowardNeedsHelp in forum MacReplies: 13Last Post: 2nd Sep 2009, 11:42 -
Menu button selection order in iDVD vs. Toast 10 DVDs for MAC
By HowardNeedsHelp in forum MacReplies: 0Last Post: 29th Aug 2009, 12:06 -
iDVD / Toast Compression No Longer Working?
By toxicquack in forum MacReplies: 3Last Post: 26th Jul 2009, 12:57 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 02:05
