I downloaded ac3fix and extracted it to a folder in "my documents". Can someone please give me step by step instructions on how to navigate to this file in dos(and what to do once I get there)? I placed my corrupted "audio.ac3" file in the folder with the ac3fix files. Now I just need help on how to use it. I am using windows XP. Thanks!(I have extracted audio and converted it successfully with headac3he before, but on this particular movie headac3he gave warning that there was corrupt data.)![]()
This worked for me and I have a Compaq computer.If you have another computer let say a Sony.Then I think you will not find Compaq in C:\Documents and Settings,you will find C:\Documents and Settings\Sony
Just extract all files to the folder.
1.Extract all files to C:\Documents and Settings\Compaq (your computer)
2.Open up a dos prompt by going to Start, Programs, MS DOS Prompt
3.Put your AC3 file in the same folder as the ac3fix (C:\Documents and Settings\Compaq)
4.Type in the words like in the picture below:
5.After that.just press enter and it will look something like this:
And tell me if it worked.
Sync issues after fixing with ac3fix
By mub6 in forum AudioReplies: 5Last Post: 24th Dec 2007, 08:56 -
Aften vs Besweet vs Super vs AC3Fix vs working
By awesomer in forum AudioReplies: 2Last Post: 18th Nov 2007, 19:28
