Hi,
I have a SVCD (mpeg file) that is 795 MB and 59 min in length. This will brun onto 1 CD with overburn, but the CD writer (HP 9300) does not support overburn.
What else can I go to fit it onto 1 CD.
Hmmm....it should fit onto 700 MB CDR/RW without overburn........you could trim the ending off a bit (i.e. end credits, if present) as a last resort.
Regards. -
To expand a little on what OKewl said. CDRs are labeled with their mode-1 capacity. VCDs and SVCDs are burned mode-2. An 80 minute CD when recorded mode-1 has a 700 meg capacity, encode that same CD mode-2 and it has an 800 meg capacity.
When I load the file in VCDEasy it says the cd size will be 806MB in red on the bottom. What does this mean.
It means the bin/cue image file will be about 806MB. I think that should be just about exactly the capacity of a CD-R80.
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 07:31 -
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 02:54 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 17:53 -
Help Fitting Videos on CD...
By skinnerback in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 17:12 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 10:08
