Not sure if this is me, Nero or Spruceup but I had a heck of a time getting Vcd's to burn properly on a DVD+rw. The problem was that the inital menu would not load in the Dvd player (stand alone.) I used spruceup to create the disk layout, then copied all the files to Nero as a DVD video. This same method worked for me with Svcd's. I was able to get it to work finally by picking DVD ROM and copying the two folders to the layout and burning. It included a file burn.lay file which I guess was created by spruceup.
Anyone know what is going on here? Thanks.
Well over 50 views of my post but no replies. I guess the answer is not known. It does not matter much as I was able to successfully burn the vcds to dvd with nero. I just used the dvd-rom method and copied all the files including the dirs.
I assume you have read this guide:
http://www.vcdhelp.com/vcddvdr.htmPanasonic DMR-ES45VS, keep those discs a burnin'
Strange subtitle issue w/Ripbot
By Rod419 in forum Blu-ray RippingReplies: 2Last Post: 28th Nov 2011, 05:17 -
Strange VCR Playback Issue
By ejk71 in forum Capturing and VCRReplies: 2Last Post: 2nd Apr 2011, 21:17 -
Strange issue with VOB
By idlebrain1 in forum Video ConversionReplies: 1Last Post: 20th May 2010, 15:12 -
Strange burning issue with DVDShrink/Nero combo
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 7th May 2010, 11:00 -
Strange Issue with Pinnacle 10.6 DVD Menus render strangely
By Kadji.Kahn in forum Authoring (DVD)Replies: 0Last Post: 26th Feb 2010, 14:47
