I have several AVIs.
Some are about 80megs. Some are about 150megs.
They appear to be rougly the same quality when watching them (including full screen).
I want to know how to shrink the 150meg AVIs to about 80megs, since they seem to be about the same quality.
It *SEEMS* to me that I need to shrink the resolution a little and lower the data rate, but any input from someone else is welcome.
Here are the stats for the 80meg AVIs (as reported by WindowsXP):
Resolution: 352x240
Audio bitrate: 127kps
Audio format: MPEG Layer 3
Frame rate: 29fps
Data rate: 54kbps
Video sample size: 24bit
Video compression: DivX codec
Here are the stats for the 150meg AVIs (as reported by WindowsXP):
Resolution: 512x384
Frame rate: 29fps
Data rate: 96kbps
.x[ DeVante ]x.
Open the larger file with VirtualDub. Select Video, Filters and choose the Resize filter. Set new size to 352/240 and click OK.
Select Video, Compression and select DivX5 or DivX Low Motion and click OK.
Select Video and choose Full Processing Mode.
Select Audio, choose direct stream copy. Click File and Save Segmented Avi.
Good luck.
"shrinking" .mkv files
By oskarom in forum Video ConversionReplies: 3Last Post: 30th Nov 2009, 07:00 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 19:11 -
Shrinking an AVI
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 15:33 -
shrinking photo files
By angryassdrummer in forum Newbie / General discussionsReplies: 2Last Post: 31st Mar 2008, 20:27 -
Preventing DVDFab HD Decrypter transcoding (shrinking) your files
By mazinz in forum DVD RippingReplies: 4Last Post: 30th Jan 2008, 18:08
