I found out that my standalone dvdplayer can do CVD subtitles.
Now I want to know if it's possible to take for example a MicroDVD (*.SUB) or SubRip (*.SRT) subtitle and add it to one of my SVCD's (mpeg2), which I have downloaded from the Internet?
If it's possible, is there then a guide or can someone tell me, which program I shall use and how to do it?
Hitman800
try this guide: http://www.vcdhelp.com/forum/userguides/87065.php#1
if you already have the movie file, skip the part in the guide where it teaches you how to rip the subs from the dvd.
if you want to edit/sync/add/remove subtitles, try 2 of my favez programs: subtitle workshop and subsync.
take care. -
Thanks I'm gonna try this guide.
As I can see this guide only deal with avi files or am I wrong? Because I have the SVCD and that is mpeg2 format. So I don't want to add the subtitles to a divx/xvid, I want to add the subtitle to a SVCD (mpeg2). But I only have the subtitles in MicroDVD and SubRip format, because I haven't ripped them or the movie by myself.
I have found this guide http://www.vcdhelp.com/svcdsubs.htm, but that seems like you have to write the subtitles from scratch. I know I could just use the subtitles I have in MicroDVD or SubRip format, and write it all down in I-author.
Isn't there a program, where you can join subtitles in MicroDVD or SubRip format with a SVCD, witout convert it to a divx and after that burn is again as a SVCD?
Hitman800 -
I used this method to add subtitles to a svcd:
Use Subadjust to convert your .sub or .srt to .SSA and then use
MaestroSBT to generate your bmps and the script (which shall be .sub if you use Winsubmux). After that you use Winsubmux to multiplex subtitles and mpeg.
But unfortunately the subtitles don't appear, when I play the movie on my dvdplayer. I don't know what went wrong, but I know my dvdplayer support CVD subtitles and not SVCD.
Hitman800 -
maybe what you did was svcd subtitles and vcd... i don't know.
but i don't think you have to write from scratch. if you do, try to cut/paste into the program the subtitles you already have. i don't know... i use the two programs i told you above and yes i take a long time (three days for blade runner, director's cut) to get the subs perfect, but i always prefer that way because i can edit and sync it better.
take care. -
Too bad you cant get I-author since there is no demo, and is only for sale in china and their site is in chinese.
I have downloaded I-Author tonight, so I will try with that, if that doesn't help then I will try with submuxgui.
Hitman800 -
I have now tried with WinSubMux, SubMuxGUI and I-author, but I still can't see the subtitles, when I play the movie on my standalone. I know my dvdplayer can handle CVD subtitles, because I downloaded the sample from vcdhelp. I also know it worked, when I watched the 3cd rip of K-19: The Widowmaker.
Hitman800
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
