  1. With the weird problem I was having with Flask, I decided I will try the Flexion guide tonight as many people seem to recommend it. My question is dealing with SVCD and what needs to be done differently. The guide only mentions vcd's so I assume I just change the resolutions where applicable to 480 x 480. Will I need to change the audio stream that is mentioned in any way or is that part the same for vcd's and svcd's? Sorry if it's a stupid question.
  2. Audio is the same 44,1khz, 224kbps, same compression.
    Higher/lower bitrates are accepted as well with SVCD.
