Using CCE do I select Joint Stereo or Stereo ? Bitrate 256 and 48khz ? Would 128 48khz work or 128 44khz ?
I understand SVCD is not a good medium for future archiving. I'm thinking about CVD's for in the future when I get a DVD burner.
I can never remember which is better between the two - I normally use joint stereo - but then again my videos are not normally noted for their distinct audio channels
if your making CVD's try 48khz - if your audio source is that - otherwise.....
and for bitrate try around 192kbps- if you know the audio is REALLY not important then - yes drop down to 128kbps or so
I switched from SVCD to CVD a couple of months back - Took me a while to work out the kinks - I have a Dazzle DVC II - I got EXCELLENT quality CVD's at a fraction of the encoding time and difficulty of SVCD and much better quality as well. I'm doing 3 pass VBR from CCE and the output looks fantastic - very closely matches the original footage
And they are all DVD compatible for when I get a DVD burner -
Can I ask what version of CCE are you using and how are you frameserving the avi to CCE ?
Also any good urls on making CVD with CCE ?
Thanks -
Ahh I'm using CCE 2.5
I recently got 2.64 - but prefer the layout and options of 2.5
I'm frameserving from avisynth using a frontend of AVSGen - cause I'm lazy
As for Url's - there's a great guide in the guide section that details most things about CVD - otherwise get yourself a small sample video and practice yourself -
For audio, for 192Kb/s or more better use stereo. For less bitrate, if you want simply stereo audio, use joint stereo. If you want to keep the souround info, use stereo for 160kb/s and dual channel for 128Kb/s
If you have a Dolby prologic 2 decoder, you can use whatever you want. Stereo in theory is still better for >160Kb/s
For CVDs, everything is exactly the same as SVCD. You change only the resolution to 352 X 576/480
Preference for MP3 Joint Stereo Vs. Stereo ?
By davexnet in forum AudioReplies: 7Last Post: 27th Oct 2011, 12:49 -
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 20:05 -
I keep losing stereo audio on my stereo bluetooth headphones (vista)
By yoda313 in forum ComputerReplies: 0Last Post: 30th Jan 2010, 10:19 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 23:24 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 10:33
