I've just tried the VCD header trick and I'm not sure if I'm doing it right. I've followed the guide but the following happens:
I tried with an mpeg file that is about 4 minutes long. When I try to play the mpeg2 with mpeg1 header in Zoom Player it says that the file is 4 minutes long which is correct. But when I try to put it in Nero it says that it is 8 minutes long. Also if I try to run it through VCDeasy it gives a lot of error messages (one or more BCD fields out of range...) and the bitrate of the file is half of the original, and when I try to burn the .bin with Fireburner, Fireburner makes 2 tracks and says that it is 8 minutes long. And when I try to play it in my DVD-player it ALSO says that it is 8 minutes long and stutters a lot and if I fast forward beyond 4 minutes there is no audio. The exact same thing happens when I play the .dat file in Power DVD on my PC. Am I doing something wrong? I've tried to multiplex with both tmpgenc and bbmpeg.
Results 1 to 1 of 1
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 09:42 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 08:36 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
