Is there anyway I can determine how many Frames Per Second (FPS)
My Computer manages to encode Under TMPGenc ?
I have been watching the frame count in the top corner increase but I dont think that this is giving me a true reading........
If I encode to Standard VCD the increment step is 18 Frames
If I encode to DVD Full D1 the increment step is 15 Frames.......
(DVD Rip using Smart Ripper & Frame served with DVD2AVI)
But, as I have already mentioned I dont think thats a true 'FPS' Reading!
Either way,
My reason for knowing is that I am toying with the idea of upgrading my processor / Computer..... from my present Intel P4 1700 to the P4 3.06 ..
And if the upgrade is realy gonna make that much difference!
If anyone would be kind enough to share their own results with this method or whatever(There maybe a better way of calculating the true FPS?)
Im running an 'INTEL P4 1700' + A Gig of 133 Ram.
Thanks in advance.![]()
whether you can tell the speed of encoding to the exact frames per second is irrelevant. Speed of encoding is directly proportional to the speed of your processor(when talking 1 P4 to another), therefore, going from 1.7 to 3.06 will net you a noticable increase in encoding speed. maybe even almost a doubling...
what are you askin' me for...
I'm an idiot! -
You mean the "frames per GOP" right???Originally Posted by kv5
Why can't mkvmerge determine fps from h.264, but mediainfo can?
By bigmweb in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2011, 11:26 -
FPS during encoding process
By godwentpunk in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2009, 13:43 -
Is 6 fps encoding for .ts file normal?
By burchis in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Apr 2009, 11:05 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
Encoding XVID from 10 FPS source
By dilly323 in forum DVD RippingReplies: 5Last Post: 15th Nov 2007, 01:00
