  1. How do you go about deleting a file when everytime I try to move it to trash a screen pops up and says it is in used by another task right now (which it isn't... I have restarted about 10 times since I have had it). At the bottom of the screen it says try again when the task is complete. I really need to remove this file. Please Help!
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    In terminal goto the folder where the file is and type: sudo rm filename.ext
    That should do it
  3. Thanks... worked like a charm!!!
    Jun 2001
    Silver Spring, MD USA
    If you're ever stumped, without an internet connection, cant remember those handy Unix commands and still have OS 9 on your computer, boot into 9 and delete the file. OS 9 could give a toss about OS X and permissions.
  5. Swollen Member
    Mar 2002
    Kanuckistan
    You can also log in as root to delete the file.
