Hi everyone,
I am trying to get to grips with CDRWin. I am trying to follow this guide:
I have created the .cue image, and modified its contents, and now it is just a question of burning the image I have created onto a CD-R. however, this is where the problem occurs, when I go to “load cuesheet”, select the image.cue, and halfway through “compiling cue sheet” an error occurs, saying “invalid CUE SHEET command at line 56 illigal cuesheet command syntax”
I have tried it several times and keep on getting the error, and it defiantly isn’t because of Winlock because I have created a image.cue, and then as soon as it has completed I have skipped the stage with Winlock and tried to burn the image back onto a CD-R, and the same error comes up!!
Does any one have any ideas? Anything would b very much appreciated!
Thanks a lot!
sorry, the guide which i was using cdrwin for is here:
http://www.vcdhelp.com/forum/userguides/107467.php
and please ignor all the “ because they just came up in exchange for all the speach commas! sorry -
Guest
try opening the cue file with wordpad or wuteva u use.....delete all the extra stuff between the "...."
example: location of movie= c:\movie\vcd\X.bin
all u want between the "..." is x.bin not the root behind it.....try that n let me kno wut happens -
hi m8,
i have tried to do what you said, but when i try to open it wordpad just crashes, and the file is 2 big 4 notepad. n e other ideas???
cheers m8!!! -
Guest
does it do this with all cue files? or just the ones u make? or just the one fer that specific movie? the cue file shouldn't make wordpad crash....and i usually open mine with notepad so i'm wondering why its to big. also....try using vcdeasy to make the bin/cue files that might werk to. try again and let me kno.
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 21:47 -
Sony capture probs
By DaveDLF in forum Capturing and VCRReplies: 13Last Post: 23rd Mar 2009, 21:20 -
A few probs with FAVC
By kronick in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 20:25 -
sync probs with dvdx
By zookeeper525 in forum AudioReplies: 0Last Post: 18th Aug 2007, 23:28 -
Avi conversion probs
By hitmanhill in forum Authoring (DVD)Replies: 15Last Post: 12th May 2007, 09:21
