I was just wondering what exactly is the difference between mpeg1 and mpeg2. I want to burn movies to cd-r, but I'd like to know whether to use mpeg1 or 2. I'm planning on capturing vhs to 352x240 (anything taller gets interlaced). 352x240 is acceptable quality for me. I'm trying to keep the bitrate low to fit 2 hours on a cdr. My dvd player can play non-standard vcds/svcds, so compatibility's not a problem.
My question is will I get better quality with mpeg2 or with mpeg1, at the same bitrate and resolution?My guess is mpeg2, but I want to be 100% sure.
The quality will be the same for the same bitrate and resolution. The main advantage of mpeg2 is that it supports interlaced video. For your requirements, use mpeg1
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 18:39 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 14:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 01:08 -
Burned an MPEG2, replicator says it's MPEG1 and unusable?
By First1 in forum Authoring (DVD)Replies: 4Last Post: 11th Nov 2007, 13:55 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 10:58
