I burn all DVD media as VCD on DVD.
My problem is that I don't want my Mpeg1 LayerII audio to be recompressed in PCM or DD or whatever.
I want to fit 460+ minutes on a single DVD.
SpruceUp does this, but in my opinion some functionalities are missing (Background sounds, text morphing).
I did a search here and found that probably Ulead DVD Workshop is the one.
Anyone can confirm or suggest something ??
PS: I need chapters support as well as good menu building/navigation.
Thanks.
I can't help you, but I know that MyDVD does recompress audio to PCM if you create DVD project.
Yes you can create a VCD-DVD with workshop without any re-encoding taking place. I have managed to fit the whole of the first series of friends on 1 DVD using this method.
Thanks,
DVDFan99 -
Dont know never tried it. If I were to take a guess I would say probrably.
DVD WS will work great, up till Saturday all I had for Analog caps was Dazzle DVC which is mpeg1, and all mine came out greeat. As for the sound, I dunno I alwarys capped the sound in 48,000 using customize option in dazzle software.
SeanWe all like Sheep have gone astray...
dvd authoring software
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 04:36 -
I need new Dvd Authoring software ?
By mrjust in forum Newbie / General discussionsReplies: 10Last Post: 28th Mar 2010, 17:13 -
Swap Replace Audio in MPEG4-AVC without recompress
By cele_82 in forum EditingReplies: 2Last Post: 17th Jan 2010, 03:09 -
best DVD authoring software??
By yunakokimama in forum Authoring (DVD)Replies: 3Last Post: 20th Dec 2007, 15:38 -
Best DVD authoring software?
By skybadger in forum Authoring (DVD)Replies: 8Last Post: 16th Aug 2007, 05:11
