I am in the process of transferring home video (camcorder) video to dvd. I capture it as an avi (huffy codec), frameserve with vdub (using deinterlace filter among others), and then use TmpegEnc to encode to dvd compliant mpeg. My question follows:
Since the original source material is interlaced should I use filters to create a progressive video during the encoding or should I maintain the interlaced video and allow my dvd player (panasonic CP-72) do the progressive conversion for me? The CP-72 makes use of the Sage/Fourajda (sp?), one of the best hardware deinterlace chips out there. Or is there additional value in encoding to progressive and then still using the progressive output of the player?
Thanks for the help!
Even DVD's, are often telecined to 29.976 frames per second, which introduces interlaced frames to a progressive stream. The primary bonus to a progressive scan player, is the resolution it will output, and not the format of the video, be it progressive, or interlaced. Save your efforts for other things.
Impossible to see the future is. The Dark Side clouds everything... -
Thanks for the reply DJRumpy. So will I derive a benifit from using the deinterlace filter in VDUB or am I just spinning my wheels? The reason I ask is that I just received a DVD-burner and want to do lots of encoding. I am wondering if adding this filter and fameserving is adding significant time to the encoding process. Right encoding with TMPGEnc is taking a loooooong time
on my 750MHz AMD processor and I am looking for any way to speed it up
Again thanks for any and all help.
If your source material is telecined, then I would spend the extra time to inverse telecine it, simply because you gain back those extra frames, saving space, and bitrate for other things. If your material is true interlaced, then I wouldn't bother. It all depends on what your working on.
If you want to use a quick and dirty IVTC method, open the AVI in VirtualDub, and from the Video Menu, select FRAME RATE. Select "No Change" for the source setting, and "Reconstruct From Fields - Adaptive" for the Pulldown setting. Save your avi for a few minutes and view the results.
It's better to learn how to identify your source, rather than guessing if it's telecined, or true interlaced. Check www.lukesvideo.com
Look under the Classifying Hi-Res. Good reading...Impossible to see the future is. The Dark Side clouds everything...
MPC-HC Transform Filter deinterlace question, searched form
By gOdiSOnyOuRsIDe in forum Software PlayingReplies: 3Last Post: 5th Mar 2012, 23:58 -
VirtualDub Deinterlace Filter yadif vs blend
By kreg in forum Capturing and VCRReplies: 1Last Post: 22nd Jul 2011, 12:42 -
Deinterlace filter for mencoder pp=lb not giving me what I need
By M3mbr4n3 in forum Video ConversionReplies: 3Last Post: 12th Apr 2011, 14:44 -
Weird problem when using deinterlace filter from VirtualdubMod...
By artyjeffrey in forum RestorationReplies: 12Last Post: 22nd Apr 2010, 10:11 -
VirtualDub Smart Deinterlace filter vs Xvid option
By StealthKing in forum DVD RippingReplies: 16Last Post: 17th Aug 2007, 11:37
