Can anyone telll me if it is worth aquiring a capture card. I am currently
using Tmpg to encode my AVI files to DVD mpeg2 and they are typicaly taking 25hrs to encode. is this normal and will a capture card help? if so any suggestions to what card.
Rewmer, try the Catpure Cards section to the left. You'll find it under Other. Unless your ready to drop a good chunck of money, then a capture card will probably not make you perfectly happy. They all seem to require a nip and tuck no matter what you get. Granted, though, I never purchased one of the $4000.00 models.
I went down this road a while back..A few suggestions.
If you do buy one, try to keep in mind what you'll be using it for. Make sure it will capture in the format your aiming for. Othewise, you'll still have to convert your capture after the fact.
Don't forget the audio. Make sure it captures in 44.1 Khz, or 48 Khz! Save yourself some time.
Remember you get what you pay for. In the end, you probably will not beat the quality of a 25 hour encode in TMPGenc, compared to a live, on the fly capture of a TV show, direct to MPEG-2. Know what your willing to accept.
Last but not least, know the return policy of the place you buy your capture card! You'll be visiting them, over, and over, and over again, until you find what your looking for.Impossible to see the future is. The Dark Side clouds everything...
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 20:14 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05
