Hi,
I'm interested in whether DVD writers - the ones that fit inside a PC - will be able to write to DVDs with the storage capacity of DVD-9 and DVD-10 as well as DVD-5 at some point in the *near* future?
I understand that at the moment I can backup my bought movie DVDs that are based on DVD-5 technology using a DVD writer but that any of my movie DVDs that are based on DVD-9/10 technology can not easily be backed up.
In other words does anyone know if DVD writer manufacturers intend to make more advanced writers soon. I guess this also brings up the question of whether the various DVD r/rw+ formats can handle larger sizes that 4.3GB?
Thanks and regards,
..matthew
Originally Posted by mattstan
DVD-9 is data that is on 2 different layers, so its unlikely we will ever see a DVD writer capable of this, as writing the second layer would surely FUBAR the first -
> DVD-10 is just a dual sided DVD-5 disk.. All DVD writers
> should be able to do these now..
Does that mean you can backup bought movie DVDs that are either DVD-9 or DVD-10 with blank DVD-10 media in a PC's DVD writer? I thought this was not possible at the moment.
Thanks and regards,
..matthew -
The only problem is that if you copy a movie from DVD-9 to DVD-10, is that you have to get up, and flip over the disk -
DVD9s are made in the factory, at current there is no way to burn them, and likely there will not be.
There how however some dual sided DVD-Rs out there, Princo makes some (yuck) and Pioneer does also but they are very expensive. -
My understanding is that a DVD-10 is useless because it is essentially two DVD-5 disks glued together. You would have to flip it to use both sides. So you are better off buying two DVD-5 instead given that it is just as easy to change disks than to flip a disk. Furthermore, it is much cheaper to buy 2 DVD-5 disks than to buy a single DVD-10 disk.
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 21:34 -
Sony and Optiarc DVD writers
By anfield7 in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Oct 2009, 22:44 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 01:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 13:51 -
Buying 2 SATA DVD Writers
By mis3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Aug 2007, 22:08
