I just started to make VCD's with TMPGEnc and I have sucessfully created VCD's that work with this TMPGEnc and NERO. But I have a small problem. The movies come out fine except the video is stretched...meaning the video looks stretched length wise. so the people look skinny and tall. It's not real bad, but enough to get anoying after a while. Is there a way to fix this? Thank you.
Source aspect ratio - 1:1(VGA)
Video arrange method - Full screen(keep aspect ratio). -
need help!! i'm using the same program to make vcds, the quality is good but for some reason everytinme i try to convert a 640x480 file to vcd the picture is waay to big and subtitles are off by alot. I tried every option on tmpg and it sitll doesnt work soo somebody help me!!
The above settings with the standard VCD template loaded should work perfectly.
TMPGenc 4.0 XPress Question
By spliffy in forum Video ConversionReplies: 1Last Post: 19th Oct 2009, 17:04 -
TmpgEnc 4 XPress Question
By VEBouto in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2009, 19:36 -
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Aug 2008, 23:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 08:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 04:38
