I use Nero 5.5 using guide here, so no problem. It also starts play without any problem in my DVD Player (Grundig GDV 130). But when I try use fast forward, rewind function or pause, it doesn't work, it will show crossed circle. But some VCD's works fine, so what's wrong?
Would you help me please? Thanks.
Johny Becher. Friend of yours ;)
hi m8,
i aint an expert but i thought i would reply cos u have had 30 views & no replies!!!
i would guess it is a problem with your DVD player, try playing the movie on your pc with software such as power dvd or windvd. if there is no problem with them then the chasnces are it is your player.
also, you could try to copy the mpeg file from a working VCD and then re burn it onto a new cdr, then try to play it in your player. if it doesn't work then it is almost certainly your player.
also, try the movies which dont work in your player on other peoples dvd players!!!! -
Thanks body, you're kind
Well, should not be problem with DVD Player, I've checked compatibility list and all GDV-130's users have no problem with playing VCD's.
But I get shocking news right now: I put the VCD into DVD Player again and it works!!actually:
Probably DVD Player had badly read the VCD and all the others which I've mentioned. It seems when I will experience this problem again, should be enough to try it open and put VCD into it again...
Probably problem with CD-W ROM? High burning speed?Johny Becher. Friend of yours ;)
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 15:23 -
Burning .srt along with .avi onto a VCD
By wox in forum Authoring (VCD/SVCD)Replies: 3Last Post: 5th Jul 2008, 08:35 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 07:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 06:23
