ok in tmpeg when i convert only certin movies it works for 35% of movie then just shuts down ,
i also tried using avitovcd that worked to convert the file but it is upside down , what did i do wrong in avitovcd and in tmpeg i have raised the direct show to have same results just stops encoding
hoping someone can help
thx
You said only "certain " movies do this...not all?
Have you succesfully converted AVI to MPEG?...if so >
If its AVI ,Try running the movie through Virtualdub to clean it up :
http://virtualdub.sourceforge.net/
Then if that does'nt work ,you can run it through DivFix to check for errors:
http://www.divx-digest.com/software/divfix.html
If you find errors ,do a more in depth test using this method:
http://www.vcdhelp.com/forum/userguides/117930.php
You could also make sure you have the FFDSHOW (Direct Show filter):
http://sourceforge.net/projects/ffdshow"Today is only yesterdays tomorrow" -
Download and install the Nimo Codecs if you haven't done so already. This should help out.
thx for the responce i have nimo , divx and tm? codecs ,
i will read the links u posted thx
problems when converting and resizing
By shaktiIIIgta in forum Video ConversionReplies: 13Last Post: 2nd Apr 2010, 20:32 -
Problems converting rm files
By kcahill in forum ffmpegX general discussionReplies: 23Last Post: 7th Dec 2008, 20:03 -
Different converting problems
By saiden22 in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 13:29 -
Problems converting from MP4
By bboypkj in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 21:57 -
Problems while converting ts files
By vertical in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jun 2007, 15:01
