I just installed the dvd burner and all my blank disks are being reported as 'audio cd's' with 1.99 gigs used and 0 bytes free. On the disk i can see a 1.99 gig .cda file. It's not a compatibility issue because one of the disks came with my burner, what do i DO???????
you might want to look at the documentation. There may be something about playing a NORMAL DVD to establish region code. I had this problem at first as well.
hmm, i played barbershop last night just fine, and tried burning this morning.....
i had the same problem did that fix it i have the drive around in my mates hs and i m to lazy to get it to see if this works
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
What's you choice when it come's DVD-R blank media?
By mrjust in forum Off topicReplies: 4Last Post: 24th Mar 2010, 21:24 -
looking for the best site to buy blank media
By hardy in forum MediaReplies: 6Last Post: 3rd Mar 2010, 22:37 -
Blank DVD Media
By jason in forum Newbie / General discussionsReplies: 21Last Post: 2nd Dec 2008, 12:40 -
Blank media revisited
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2008, 10:57
