  1. Guest
    Hi!
    I've converted some movies from DivX to mpeg2 using TMpeg
    newest version, and the newest DivX 4 codec, and it works
    ok, but when I use TMpeg to split the movie in two parts the last 30 seconds on both parts have no sound. Appart from that there's no problem with them.
    I have done this before whitout any problems, but now the same thing happens on all movies I convert. Does anyone have a solution?
    Thanks,
    Peter Logarn
  2. The same thing happens to me. I've been through all the forms to try and get a fix. Seems like it's not that common.
    Anyone HELP !!!
    Sep 2000
    Northern Virginia
    you may wanna try tmpgenc 12 or 12a for cutting that mpeg...
