I have an ATI AIW 8500DV which is working overall well, but:
When capturing using the ATI TV capture, I get good captures on startup,
but when I stop capturing and start again(without closing ATi TV and opening again) the second capture will be choppy, with lots of color blocks/garbled video(audio remains good).
IF I close the ATi tv program, and restart after every capture, I have no problem....but trying to record more than one thing overnight results in one good capture, and the rest worthless.
There does not appear to be an auto-shutdown for the ATi tv after each capture....
Has this happened to anyone out there? Any ideas on a solution?
thanx
Start by downloading Switch off from here: http://yasoft.km.ru/eng/. This application can be used to force a restart at designated times (via the scheduled task function of Windows).
I use it after EACH recording to ensure that the machine can go into Standby between recordings. It works flawlessly for this cause.
Good luck!
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
I can't get my ATI tv wonder PCI 650 to capture
By Onceler2 in forum Capturing and VCRReplies: 5Last Post: 28th Nov 2009, 10:47 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 02:03
