I would appreciate some feedback on what people think is the best CD-R media for VCD's. Have some old TV shows (in B&W) that I want to put on the best quality media possible. Everything plays on my standalone(so far), so just intrested in what some people think..
THANKS ALL
"The software said Win XP or better, so I Installed Linux"
I have had good experience with fuji & sony
although sony does not overburn very well and fuji did overburn very well.
no coasters in either spindle -
I have done some extensive searching about this subject on the internet. One day I spent over four hours, trying to find a general consensus as to which CD-Rs are the best quality blanks. During my search I found more people recommended Fuji, Kodak (no longer being produced they dropped their CD-R line) and Taiyo Yuden. Fuji's latest 48x CD-Rs are made by Taiyo Yuden.
My research also showed that CD-Rs are kind of like VCRs in that there are lots of different companies that put their name on a product, but in actuality there are much fewer manufacturers and many are relabelled to a particular companies' name.
There are utilities out there that will do a test and tell you the "true" manufacturer of a CD-R disk. I use one called CDR Identifier.
I am a firm believer in "You get what you paid for." I expect you will get some answers like "I just buy the cheapest I can find" or "I have never made a coaster with XXX brand." Consider this: there is a lot more to quality that just, can I do a successfull write the first time. Some other charcteristics to think about are: scratch resistance, will the dye fade with time or heat, will the surface peel with time, will random errors appear with time, etc.
Now that I have found out the above mentioned information, I only buy Fuji CD-Rs as they are the only ones of the three that I mentioned that I can readily find in my area. The cheapest I have ever found these is $15 USD/50 CD spindle. -
I buy my Taiyo Yuden CDR's for $0.29 Each in a 100 Bee Hive Case. Which is pretty cool. I know we all have stacks of disks sitting around that we should store. TY (Taiyo Yuden) Supplies a Bee Hive Case for that very common situation. You should try them out. I purchased them from http://www.atdiscount.com/community/cdr/index/3/199/1192/product/20581/sku
I know the picture does not but show it but you get one. Mention VCDHELP when you order and you may be surprised. -
If you are just looking for opinions, why are you posting in the latest news forum.
Moving to media. -
just buy a couple of cd's and use nero cd speed and check what dye type is used type " 6 " is very reliable
Need Opinions On Video
By budwzr in forum EditingReplies: 0Last Post: 23rd Aug 2011, 13:18 -
Opinions wanted
By Nelson37 in forum Off topicReplies: 14Last Post: 31st Dec 2009, 23:29 -
pc to tv hook up need opinions
By xsfcloud in forum ComputerReplies: 6Last Post: 4th Aug 2009, 13:51 -
Looking for honest opinions
By xtremegamerx in forum Newbie / General discussionsReplies: 15Last Post: 7th Jan 2008, 21:36 -
Opinions Please
By OzarkBaby in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2007, 16:11
