I am experimenting with MSDVR which uses Windows media encoder 7.1 to capture .wmv video from my avertv stereo card. Then I am converting the .wmv to VCD format using TMPGENC. Seems to give good results as compared to using PowerVCRII goint straight to VCD (or 1500k XVCD) format. I may try AVI capturing but want to make it easy and fast to convert to VCD format. TMPGENC converts .wmv. to VCD at about a 1.5:1 ratio (1.5 seconds to encode 1 second of .wmv video)
ANy comments or suggestions?
Hi
Have u tried high bitrate captures in powervcr then encoding to VCD???
Gives me good results.
Fozz -
I am trying CVD encoding this week using hacked powervcr registry. I gave up on .wmv becuase the MSDVR proggie isn't working right.....
I am just trying to find the right settings to produce good video using powervcrII -
Hi
Read this post telemike
http://www.vcdhelp.com/forum/viewtopic.php?t=132912&highlight=fozzee
I get good results on the settings I gave there.
Mind you I've got PowerDirector Pro now and that gives even better results at the same settings.
Fozzee
Movie_LeftEye.wmv + Movie_RightEye.wmv + Polarized glasses = ?
By barelief in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Nov 2011, 16:45 -
WMV to DVD or VCD Conversion
By MannyNoela in forum Video ConversionReplies: 9Last Post: 6th Feb 2008, 11:22 -
Removing Subtitles from VCDs and VCD-originated MPEG and WMV files....
By dadada_999 in forum SubtitleReplies: 1Last Post: 2nd Jan 2008, 20:49 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
