Okay I'm new at this and it's driving me crazy. I get the VIDEO_TS ready to go and I started off using nero but was having problems with the DVD not working on some players.
So after reading some forum opinions I tried Recordnow Max. The first DVD went off without a hitch, then it was all down hill from there. Whenever I create a new data disk in recordnow and move the folder over to the folder and file area they turn red and the program gives me an error code when I hit record.
Does anyone know what I'm doing wrong.
Results 1 to 9 of 9
Be aware that there are different versions of RecordNow....
RecordNow
RecordNow DX
RecordNow Max
and maybe more.... -
That error probably has something to do with the fact that you are stripping movies with IFOEdit and not getting VTS Sectors. Either that, or you are keeping that default powerdvd file in the folder which makes the VIDEO_TS folder, non_compliant. But if you did the first DVD without a hitch, then that was probably because you made a direct backup of a single layer dvd and now you are stripping and didn't get VTS Sectors. If you did use IFOEdit, get VTS sectors on the main movie .ifo file and you should be set. Let me know if that is what it was.
I have had same problem. I been using Prassi 2.0, same really as RecordNow. I find that if I keep menu then Prassi will not burn it. So I use Nero and it's OK.
If I do movie only using IfoEdit then Prassi has no problem with it then.
All movies have worked in player and I did do get VTS sectors each time. I am just starting DVD to DVDR and I don't have a clue why this is happening though.
You could try Gear Pro 6. That won't let you burn a bad DVDR.
How do you record with Recordnow MAX anyway? Seems not to be as easy as Nero anyway. Is Data disc the right optionto chose, and then add the VIDEO_TS folder. Or is there anything else that should be done to make it work? How did you do it smiggy? Maybe it has something to do with this...
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 13:53 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Max I Frames on DVDs
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2008, 18:19 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
