Okay. I am trying to rip my first dvd into a svcd and am using the smartripper-flask-tmpgenc method as it is a HK film where I need the subtitles.Everything seemed to work properly until I started up Tmpgenc. The encoding process started and showed that it would take 156 hours. I read others had this and it would eventually go down to normal during the process. I then noticed that there was a percentage running in the back for the flask program. Should both of these programs be "running"? I was under the impression that frameserving just keeps a window open but there would be no flask activity. Anyways, I checked it this morning after about 8 hrs and flask said it was 82% done but tmpgenc said 4% done with 150 hrs left. I don't know what was going on so I stopped everything, and checked the mpg file that was being created. It was the majority of the movie so why the 4% from tmpgenc? Any ideas if both programs should be running like that?
Results 1 to 1 of 1
TMPGEnc MTS to mpeg-4 problem/question
By Justice37 in forum Video ConversionReplies: 0Last Post: 11th Aug 2010, 16:30 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 30th Aug 2009, 23:40 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
How to frameserve this resizing algorithm to TMPGEnc?
By DRP in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 22:19 -
Frameserve from VirtualDubMod to TMPGEnc
By pchan in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 08:13
