Hi,
I have a HI-8 camcorder, almost 3 hours recording of my daughters infancy days.
I need to capture this on my PC to cut to a VCD later on.
I have a Belkin IEEE Firewire Card that I use in conjunction with my DV Camcorder.
However is there a converter or hardware device to capture from a HI-8 camcorder that does not feature a DV In/Out Port, but has a standard Video Jack you can use to connect to a VCR or TV.
I had tried the same via a TV Tuner card, but the reception and the quality is louzy as compared to the DV Quality. The main problem is the time it takes and is very unreliable....
If anybody can provide me information with regards to some kind of convertor that will enable me to capture via the Firewire Card, I'd be very gratefull.
Thanks and regards,
Yezdi
You are looking for the Canopus ADVC-50 or ADVC-100. They are made to do exactly what you want. Read about them in the Capture Cards section of this website.
Internal Capture Card? Possible to Capture direct to PC?
By Ryutso in forum Capturing and VCRReplies: 11Last Post: 25th Jul 2010, 16:58 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 10:09 -
Capture from Sony Camcorder/Firewire connection stopping in 4-12 seconds
By tepeco in forum Capturing and VCRReplies: 4Last Post: 16th Apr 2009, 12:24 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
