Hi, I have seen that someone has posted this topic some months ago and I have also check you the left panel about "How to Convert ..." But all says about the asf-video to convert. The VirtualDub does not recognize the file and doesn't open it coz there's no video-part in it.
Does anyone know how I can convert it to the other format(s)?
Thank you, flips
Check out ASF Tools, or Power WMA/MP3 Converter. ASF audio is the exact same as WMA or WMV, so just change the file extension if you choose to go with the latter. I am not sure if Power WMA/MP3 Converter can handle ASF/WMV video files and extract the audio. ASF Tools can do that quite easily though and extract it to a .wav file.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 11:07 -
convert dts 5.1 wav to ordinary mp3 etc.
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 06:02 -
Convert MP3 -> WAV, Copy to HD and RIP
By ctdvd in forum AudioReplies: 4Last Post: 23rd Jan 2010, 07:32 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 20:07
