  1. Hi,
    I wonder if anyone can help, im trying to convert a DVD to SVCD im using DVDx so what would be the best resolution,
    480 * 480
    480 * 576
    or any other, i know i can customise the DVDx to any resolution i want but i dont wanna waste disks for no reason, if anyone can help it'll be gr8,
    thnx
    kas187
  2. if you read http://www.vcdhelp.com/svcd you will see that the valid resolutions for an SVCD are 480*480 for NTSC and 480 * 576 for PAL. So use whichever resolution matches the format of your source DVD.
  3. Thnx bugster
    i read the link, and it was great, i managed to copy a dvd or to CD-R with success and the picture and sounds quality was excellent,
    kas187
