  1. Firstly, I would like to say one my first post, thanks for all the help I have already got from the guides and forums. Well done to all.
    Secondly......
    I have a problem with mpeg 2 playback and encoding. I'm wanting to re-encode a .m2v file (used tmpgenc to demux) to reduce its size. It's run length is 57min 30, but when I load it into tmpgenc, it reports a run time of 38min 43. Also when I try to play the file in WMP it reports the same time. When I go to properties in WMP it tells me that it's using the:-
    Elecard MPEG2 Video Decoder
    I don't have problems on my other machine which is using the
    Ligos MPEG2 Video Decoder
    With the Elecard, I also get a lettle 9 square symbol in the top right hand corner of the play back and consequenlty witht the video being shorted the sound drops out of sync.
    I did have another codec problem, trying to play back Xvid, but found after much searching that a green screen playback problem was down to Nimo codec pack and un-installed it as recommended, now my Xvid plays ok, but I still have this problem. I have tried re-running the ligosinstaller which is with Ulead DVDF, and I have Ligos in the enviromental settings in tmpgenc.
    So I just can't work out what the problem is Is there a way that I can manage codecs? Or a simple way to choose which codecs are used and when?
    Thanks for any help in advance
    Tigz
  2. Banned
    Jun 2001
    UK
    TMPGEnc + ... They recommend 3 codecs. Ligos, Sony and CyberLink.
    I recommend you install CyberLink, Power DVD 4, its Mpeg 2 codec works very well with WMP and TMPGEnc +
    Can not play MPEG-2 file I have made.
    MPEG-2 file can not be played only by Windows. You need to install a DVD software such as WinDVD, PowerDVD, then you can play MPEG-2 file with Windows Media Player.
    Although there are so many MPEG-2 decoder which can be installed onto Microsoft DirectShow. Not all of them can be worked for TMPGEnc.
    There are several decoder which is;
    - not stable, as a result TMPGEnc Plus looks like unstable in previous version.
    - not allow other application to use the module, as a result, TMPGEnc can not read movie file.
    TMPGEnc reads MPEG-2 files only with specific official commercial legal MPEG-2 decoders made by CyberLink, Ligos and, Sony so that TMPGEnc reads MPEG-2 files most appropriate way by operating these decoders directly from TMPGEnc.
    In this way, it improves the stabilities to read files, but only if one of these 3 decoders installed in your system. Other decoders can not be controlled by TMPGEnc.
  3. Thanks for your reply.
    How do I get shut of this Elecard codec? ANd how do I stop other programs installing these bad codecs?
    I don't have a check box in Tmpgenc for elecard, and WMP defaults to it.
    grrrrrr
    Cheers
    Tigz
  4. Banned
    Jun 2001
    UK
    grrrrrr
    Cheers
    Tigz
    oops, made an edit !!
    Check your settings in TMPGEnc > Option > Environment settings >VFAPI Plug-in . From there you can enable or disable plug-ins or set their priority level (Right click) to increase/decrease
    Some programs wont function if you remove what they install, some hardware devices will also install these codecs. Install Power DVD 4 last should fix the problem, with a priority of 4 in TMPGEnc
  5. Re done the priorities, and seems sorted many thanks
    I'll do some coding over night, and re-try the playback tomorrow.
    Thanks again
    Tigz
  6. Banned
    Jun 2001
    UK
    Your welcome
