After reading all the glowing reviews on this unit, I took the plunge. Unforunately, it wont play SVCD's or low-resolution DVD's without the top of the screen flickering about 3-4 times every five seconds. These SVCD's and low-res DVD's play fine on my Samsung S221. I've even tried burning just the mpeg files to a CD, which the Cyberhome unit will play - but they flicker also. Professional DVD's and VCD's play fine. Here is the template I'm using for my low-res DVD's. Is it a problem with my encoding? Also, I tried to update the firmware, but no luck. Has anyone in the USA been able to successfully update their firmware?
object TMPEGConfigFile
MPEG.Text = ''
MPEG.WizardCategoryName = ''
MPEG.WizardSubFormatName = ''
MPEG.WizardCaption = ''
MPEG.WizardDescription = ''
MPEG.OutputStreamType = MPEG_OutputStreamType_System_VideoAudio
MPEG.OutputStreamType_ReadOnly = False
MPEG.Video.StreamType = MPEGVideoEncoder_StreamType_MPEG2
MPEG.Video.StreamType_ReadOnly = False
MPEG.Video.Width = 352
MPEG.Video.Width_ReadOnly = False
MPEG.Video.Height = 240
MPEG.Video.Height_ReadOnly = False
MPEG.Video.YUVFormat = 1
MPEG.Video.YUVFormat_ReadOnly = False
MPEG.Video.DC_prec = 1
MPEG.Video.DC_prec_ReadOnly = False
MPEG.Video.VideoEncodeMode = MPEGVideoEncoder_VideoEncodeMode_Interlace
MPEG.Video.VideoEncodeMode_ReadOnly = False
MPEG.Video.FrameRate = 4
MPEG.Video.FrameRate_ReadOnly = False
MPEG.Video.AspectRatio = 2
MPEG.Video.AspectRatio_ReadOnly = False
MPEG.Video.RateControlMode = MPEGVideoEncoder_RateControlMode_VBR_2PASS
MPEG.Video.RateControlMode_ReadOnly = False
MPEG.Video.MaxBitRate = 0
MPEG.Video.MaxBitRate_ReadOnly = False
MPEG.Video.MinBitRate = 0
MPEG.Video.MinBitRate_ReadOnly = False
MPEG.Video.CBR_BitRate = 3000000
MPEG.Video.VBR_MultipassVBRAlgorithm = MPEGVideoEncoder_MultipassVBRAlgorithm_MultipassCQ
MPEG.Video.VBR_AvgBitRate = 2000000
MPEG.Video.VBR_MaxBitRate = 6000000
MPEG.Video.VBR_MinBitRate = 192000
MPEG.Video.VBR_MaxPassCount = 2
MPEG.Video.VBR_Quality_P = 0
MPEG.Video.VBR_Quality_B = 20
MPEG.Video.VBR_EnablePadding = True
MPEG.Video.MVBR_MaxBitRate = 8000000
MPEG.Video.MVBR_MinBitRate = 2000000
MPEG.Video.MVBR_Quality_P = 0
MPEG.Video.MVBR_Quality_B = 20
MPEG.Video.MVBR_EnablePadding = True
MPEG.Video.AVBR_Quality = 50
MPEG.Video.AVBR_MaxBitRate = 8000000
MPEG.Video.AVBR_MinBitRate = 2000000
MPEG.Video.AVBR_EnablePadding = True
MPEG.Video.CQ_Quality = 65
MPEG.Video.CQ_Quality_P = 0
MPEG.Video.CQ_Quality_B = 20
MPEG.Video.CQ_MaxBitRate = 8000000
MPEG.Video.CQ_MinBitRate = 2000000
MPEG.Video.CQ_EnablePadding = True
MPEG.Video.VBVBufferSize = 229376
MPEG.Video.VBVBufferSize_ReadOnly = False
MPEG.Video.GOP_SeqHeaderInterval = 1
MPEG.Video.GOP_SeqHeaderInterval_ReadOnly = False
MPEG.Video.GOP_I_FrameCount = 1
MPEG.Video.GOP_I_FrameCount_ReadOnly = False
MPEG.Video.GOP_P_FrameCount = 5
MPEG.Video.GOP_P_FrameCount_ReadOnly = False
MPEG.Video.GOP_B_FrameCount = 2
MPEG.Video.GOP_B_FrameCount_ReadOnly = False
MPEG.Video.GOP_BitStreamForEdit = False
MPEG.Video.GOP_BitStreamForEdit_ReadOnly = False
MPEG.Video.GOP_MaxFrameCount = 18
MPEG.Video.GOP_MaxFrameCount_ReadOnly = False
MPEG.Video.QuantizeMatrix_Intra_ReadOnly = False
MPEG.Video.QuantizeMatrix_NonIntra_ReadOnly = False
MPEG.Video.Profile = 4
MPEG.Video.Profile_ReadOnly = False
MPEG.Video.Level = 8
MPEG.Video.Level_ReadOnly = False
MPEG.Video.VideoFormat = 2
MPEG.Video.VideoFormat_ReadOnly = False
MPEG.Video.DisplayWidth = 0
MPEG.Video.DisplayWidth_ReadOnly = False
MPEG.Video.DisplayHeight = 0
MPEG.Video.DisplayHeight_ReadOnly = False
MPEG.Video.MotionSearchSpeed = MPEGVideoEncoder_MotionSearchSpeed_Slow
MPEG.Video.MotionSearch_AlwaysHalfPel = False
MPEG.Video.UseFloatDCT = False
MPEG.Video.QuantizeMode = True
MPEG.Video.QuantizeModeVal_Intra = 35
MPEG.Video.QuantizeModeVal_NonIntra = 35
MPEG.Video.YUVBasicYCbCr = False
MPEG.Video.QuantizeMatrix_Intra = {
081013161A1B1D22101016181B1D222513161A1B1D22222616 161A1B1D222528
161A1B1D202328301A1B1D202328303A1A1B1D22262E38451B 1D23262E384553}
MPEG.Video.QuantizeMatrix_NonIntra = {
10111213141516171112131415161718121314151617181913 14151617181A1B
14151617191A1B1C151617181A1B1C1E1617181A1B1C1E1F17 18191B1C1E1F21}
MPEG.Audio.StreamType = MPEGAudioEncoder_StreamType_MPEG1_Layer2
MPEG.Audio.StreamType_ReadOnly = False
MPEG.Audio.SamplingFrequency = 48000
MPEG.Audio.SamplingFrequency_ReadOnly = False
MPEG.Audio.ChannelMode = 0
MPEG.Audio.ChannelMode_ReadOnly = False
MPEG.Audio.CantUseMono = False
MPEG.Audio.BitRate = 224000
MPEG.Audio.BitRate_ReadOnly = False
MPEG.Audio.CalcCRC = True
MPEG.Audio.CalcCRC_ReadOnly = False
MPEG.Audio.OriginalFlag = False
MPEG.Audio.OriginalFlag_ReadOnly = False
MPEG.Audio.CopyrightFlag = False
MPEG.Audio.CopyrightFlag_ReadOnly = False
MPEG.Audio.PrivateFlag = False
MPEG.Audio.PrivateFlag_ReadOnly = False
MPEG.Audio.EmphasisType = 0
MPEG.Audio.EmphasisType_ReadOnly = False
MPEG.System.StreamType = MPEGSystemEncoder_StreamType_MPEG2_Program
MPEG.System.StreamType_ReadOnly = False
MPEG.System.CommentText = ''
MPEG.System.EnableCommentText = False
end
Any help appreciated.
JR
Bump.
The top of the screeen flickers even when playing the raw mpeg-2 file instead of the SVCD, also. So it's not the disc... MPEG-1 files play just fine. When I load the file into PowerDVD and look at the properties, it shows PAL as the video method and the resolution at 352x288, even though I encoded at 352x240 and NTSC. Strange. But Windows media reports the proper resolution at 352x240, though it doesn't tell whether the file is NTSC or PAL. I wonder if the Cyberhome drive is reading it as PAL also and trying to upconvert to NTSC, causing the flicker...? I've double checked my encoding parameters and they are set to NTSC. I tried setting them to "unspecified" and PowerDVD still showed them as PAL. VCD MPEG files show up as NTSC within PowerDVD.
My Samsung S221 plays these files just fine. Do I have a faulty player?
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
problem with cyberhome ch-dvr player/recorder
By kayjay3k in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2010, 17:27 -
CyberHome DVD Recorder
By JRPAT in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Sep 2008, 19:08 -
Cyberhome DVR1600ME2 firmware
By DogDoor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Jun 2008, 16:45 -
newbie archos 402 video question
By brucey2 in forum Portable VideoReplies: 0Last Post: 28th Dec 2007, 05:28
