When I have to reencode a DVD to back it up to one disk I use the Guide for dummies instructions. I Rip then use TMPGenc to reencode the video. One thing I've noticed and I am thinking maybe it's an improperly set flag or something, when I Do 2.35 Wide movies and play them back on my 4:3 TV the letterboxing is off, it's more like a 1:85 ratio film. On my Widescreen set it looks fine. If I play the original in the 4:3 set it too is also at the correct ratio. So it's not a setting of the player even thou I tried all the settings.
Any tips appreciated.
When I first got into this, I had the same problem doing WS movies. I own both a WS TV and a Normal TV and I wanted to make sure they played back perfectly on both.
After reading alot of messages and asking alot of questions, the solution was for me to use IfoEdit to tweak the .ifo files before I burned the DVD
If you open up the .ifo file with IfoEdit and then change the movie ratio to 16:9 and select the Force Letterbox selection
This will show perfectly on your WS TV and then force itself into a perfect letterbox on your 4:3 TV -
So go thru the entire proceedure then right before burn go into the video_ts dir and do this? What do you do open the .ifo file make a change and then save it?
Exactly, after you author it, just before you burn itOriginally Posted by Scarpad
Some mistakes that I have made so you do not do the same thing
When you open up the .ifo file you will see both a selection for the Menu and the Movie. Just do the movie
I did the menu once and it really messed up my buttons. (if you created a movie)
Just to make sure, I have always opened up both the Video_TS.ifo and the vts_1.ifo (and any others if you are doing multiple episodes) and made the changes. I think you only need to do the vts one but it has never hurt me to do both
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
