When I try to convert some DV footage to DVD formatwith MS6.5 (or 6.0) with DVD plugin or DVD MF, I'm getting a wrong filesize after the conversion when the result mpg is greater then 2^32 Byte.When I adjust the framerate a little below, it reports a negative filesize during conversion, but the result is fine.
If I'm getting the wrong filesize, the result file can't be played back and can't be converted to DVD.
Example:
footage is 116 Min, Bitrate 625 KByte/s ->used disk space 40 MB
Bitrate 613 KByte/s -> used disk space 4,189 GByte
Isn't it possible to creata DVD compliant mpgs > 4.2 GB? And if, how?
Results 1 to 1 of 1
DVD Recorder Captures at Wrong Size
By MasterOfPuppets in forum Capturing and VCRReplies: 3Last Post: 22nd Feb 2010, 20:51 -
Wrong image size ratio after AVI to DVD encoding
By video34bgi in forum Video ConversionReplies: 2Last Post: 22nd Jun 2009, 10:45 -
rmv Plugin for Ulead VideoStudio
By Metalgod in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2008, 22:22 -
solved -edited menu wrong size in dvd player (pgcedit)
By spiritgumm in forum Authoring (DVD)Replies: 3Last Post: 9th Oct 2007, 00:00 -
Wrong Size at Spliting
By Flowbax in forum EditingReplies: 3Last Post: 16th Jul 2007, 13:33
