Im trying to convert an avi film to vcd. I extracted audio to wav with golden wave and then went to convert avi and wav to MPEG. Picture has come out fine but sound is slightly out of synch with actors lips. I even used lame.exe to improve sound quality but didnt make any difference - can anyone help me as its driving me nuts !!
Thanks Guys
Tracer Tong
tracer,
when you have your file loaded in TMPGenc, go under the 'Advanced' tab, then double click the 'Source Range' option. It will take you to another window where you will see another option called 'Audio Gap' it should default to 0 when you open it. This is measured in milliseconds and the the way to correct audio is to enter a value in this field, positive value shifts the audo forward and a negative value shifts if backward. I just kind of eyeball it and guess how much the audio is off and start in increments of 100ms's.
Just do about 2 or 3 min of video at a time to determine if you have synched up the A/V, so you dont have to wait through the entire movie being encoded. Once you determine the time (ms) it is off then just encode the whole movie as normal.
good luck -
In my experience it is only a few, the few I had to had VBR audio, or the video somehow got corrupted.
Changing sound synch
By SurreySpring in forum Video ConversionReplies: 1Last Post: 14th Nov 2011, 15:16 -
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 17:20 -
Convertxtodvd causes sound synch problems with some films
By johnharlin in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 01:15 -
Virtualdub used with or without AviCutter=Sound Synch Problem
By johnharlin in forum EditingReplies: 11Last Post: 29th Dec 2007, 12:13 -
Xilsoft MP4 converter - Sound out of synch
By digitalred93 in forum Video ConversionReplies: 1Last Post: 17th Dec 2007, 05:59
