Hi all,
Sorry to bother but im having trouble re-encoding this Xvid Buffy Episode. I tried doing it through TMPEGenc and the file comes to over 1 gig which doesnt seem right, when a normal episode is arounf 430mb. When I Stopped it and played it back there was no sound. Your help will b greatly appreciated. Thanks![]()
Gaz,
What format are you encoding it too in TMPGenc ? VCD or DVD ?
If it is DVD or SVCD then it will get bigger and a little over 1 GB sounds about right if the Xvid file is around 420MB. MPEG2 does not seem to compress as well as MPEG4 which is what Xvid is. If you are trying to fit it onto CD's you will have to split it onto 2 CD's most likely. You can adjust the S/VCD settings and lower the quality to try and fit it onto 1 CD, but that is up to you.
As far as no sound, that means the audio must be in either MP3 or AC3 format and must be de-multiplexed in Virtualdub or anther program like it, and coverted to WAV and then remultiplexed back into the Xvid video file and then put into TMPGEnc and encoded. The guides to do this I believe are on this site. If not, checkhttp://doom9.org/ they have a very good site for anythig Xvid related. -
Then perhaps you could try a VCD template, their are some tweaked to fit larger movies onto 1 CD, though I am unfamiliar with them. This site I am sure has them though.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 14:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 19:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
