I have just started to experiment with encoding at automatic vbr cq with TMPGEnc. I am happy with result but have alot of trouble trying to split the file to fit on 2 cds. TMPGEnc works OK with standard vcd but there is a bit of a audio sync problem and with any xvcd it locks up every time i try to split the file. I now use vcd cutter to do the splitting it works great with standard vcd's but with vbr mpgs there is always a time error. For example I mark in and out exactly where i want the file to split eg. 70 mins. but the resulting mpg is split at 68 minutes and the error is different for each movie. With a lot of calculating and generating clips with bad timing the error for individual movies can usually be calculated but its a big hassle. Can anyone please help me fix the problem or recommend a freeware or cheap (less than $100) program that will eliminate the problem.
Thanks,
Raptorman![]()
Results 1 to 1 of 1
Food goes in here :-)
trouble splitting and joining with mp4box
By charlieship in forum Newbie / General discussionsReplies: 7Last Post: 7th Jul 2011, 16:19 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
Trouble converting VBR Ogg to MP3
By Ryutso in forum AudioReplies: 2Last Post: 3rd May 2009, 14:19 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
Slow skipping response on MPEG1 2-pass VBR
By sparkomega in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2007, 23:19
