Is this a stupid question or
can i burn an small DVD image (100MB) on a CD-R and make the DVD player play it.
I am not looking for solutions like vcd or svcd.
if DVD-R or cd-r are just the media, the player should be just looking for some data
or file structure or something else (data) to distinguish between a DVD or VCD. In this case, can i fake the data and make the dvd player think the cd-R is a DVD and start playing it. Since i am sure the DVD player know how to decode mp2s.
Yes, i have created the DVD image and burn it onto a CD-R. It works fine in the vitual deamon. But it doesn't work in the actual DVD player.
Anyone knows why?
And what should i do to make it play onthe DVD player?
And i only need about 15 minutes of MPEG2 quality
thanks a lot
yes can do this its called mini dvd but hardly any dvd players are able to play them. might try looking up your dvd player and see if it can play mini dvds. otherwise i advise you to use svcd which is just about as good.
burn RMVB file to DVD to play on standard DVD player
By samoyed in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2009, 21:29 -
I burn a DVD and then when played in a DVD player it cuts off after 50 mins
By uk_rose in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2008, 20:43 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 02:19 -
How to burn RMVB files to DVD so it will play on regular DVD player
By MithrasX16 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 05:53 -
Can you burn Xvid files to DVD so they will play on stand alone DVD Player?
By JoeBolden in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2007, 16:48
