Now I uninstalled the PCI IDE adapter.
Again the writing begins at 4x, but after 30 seconds it decreases to a steady 2x![]()
-BK-
Results 31 to 60 of 66
Do you still have any special driver that should speed-up performance ? Like " The Intel® Application Accelerator" or any packet writing software, such as [DLA], [DirectCD], [B's CLiP] etc ???
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
No nothing like that has ever been on my system...
Who oh why ... my SONY doesn't write @ 4-speed????
-BK- -
Well...
I am out of ideas....
OK, thanks for your ideas and help anyway!!
I appreciate it...
Dunno what to do, but if I find a solution, I will let you know
-BK- -
Proabbly wont help but here goes.
1) How many Icons do you have in the icon tray on the right of the task bar. If more than 3 or four drop some.
2) Do you have a viris program running. Turn off for the test.
3) Try one of the HD spped test programs. See what is the throuput and dataspikes you get off of that data drive. Check MaximumPC they use to have a shareware test that gave a pritty good graft of what a drive could do.
4) Defrage or freshly format if you use a partition to hold your data. The one in W98 is better than the defrag in W2k/XP.
5) Compare system settings between your friend and your computer.
6) Turn off any screen savers, eye candy.
7) Long shot but if your running netbueu as one of the LAN com disable it.
8 When you remove stuff do it in savemode.
The only thing is DMA for HD, something running in the background, or hard drive throughput.
Its actually easer to speed up W9x than W2k/XP.
Good Luck
NightWing -
FINAL SONY SUCKS!!!!!
they lied about their drive SPEED.
i think SONY can do max is 2x.
cause everyone set up is rite.
even with good media noONE can burn at 4x -
No, I did get my Sony to work at 4x with the cheep Ritek media. I think the thing to look for is your CPU usage. If it's at 100% when burning, then there must be something wrong. In my case, the Promise Ultra100 IDE adapter likes Harddrives and not cdrom drives. Every burner and cd/dvd drive I but on it acted the same way....it wasn't just the Sony drive. They gave me a new driver but it's working on my onboard so I decided not to mess with it.
Have you tried putting your Sony in your friends computer just to see if it will work at 4x. Then you know at least it's not the drive. If you think this burner is a pain, try getting into some hardware video components. Yikes! -
did anyone tell BK to put the Sony burner on the secondary slave slot?
that make a difference? its recomended.what i gotta do/buy now? -
I think some one already ask this here or another thread but for those having problems what was the build date on the Sony drive having problems?
Never tried that!!!
I've always put it as master.
I'll give it a try this evening...
Tnx!
-BK- -
Just to let you all know I received my order from bigpockets.co.uk today: Datawrite DVD-R 4x. Guess what: these discs burned without problems at 4-speed on my SONY!!!
These discs are available both with printed top and white printable top (on the package of the white printables is written: manufactured for datasafe media limited by ritek, so these discs are RITEKs).
-BK- -
HOLD EVERYTHING: YOURE ALL MISGUIDED!!!!!
NO THE DRIVE CANNOT BURN -R MEDIA at 4x
YES THE DRIVE will burn 4x on +R MEDIA
YOU MUST UPDATE YOUR FIRM WARE to get 4x on the +blanks...
Yes I've used the RITEK4x MEDIA with SONY on the A05 by Pioneer
This is the spec from SONYS WEBSITE:
This new firmware will allow your Dual-+ RW drive to record at 4X on 4X compatible DVD+R media as well as improve the DVD-ROM reading performance with DVD recordable/rewritable media
NOWHERE is it supposed to do the RITEK -R at 4x
I burn this media in my A05 at work 4x
It burns in my A03 after its firmware update at 2x without damaging the drive -
DVD-R Datawrite 4x burns at 4-speed on my SONY with firmware 1.0f !!!
And what you are telling is 100% crap... the DRU500A was sold as a 4-speed DVD-R burner form the beginning!
-BK- -
My 4x Ritek media burns at 4x (just over 15 minute burn time) on my Sony DRU-500A.
Same here (Datawrite 4x seems to be Ritek 4x), just 15 mins :P
-BK- -
DON'T TELL ME MY POST IS CRAP....
GO TO SONY SITE AND SEE FOR YOUSELF
http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_DisplayProduc...ntentItemPage=
If you can get that link...you will see unless SONY is misinforming us about their own drive..IT WILL NOT BURN -R at 4 X
Specifications
2.4X max. DVD+R Write; 2.4X max. DVD+RW Write; 4X max. DVD-R Write; 2X max. DVD-RW Write; 8X max. DVD-ROM Read
also on the page
Free 4X DVD+R Upgrade now available - Click Here -
As you see: DVD-R max. 4x writingOriginally Posted by dcsos
I already burned a coupke of 4x at 4x, so be cool, dude!
-BK- -
OOPS, getting old..couldn't even see my own post!
Sorry all -
Could be, although I have my DRU-500A hooked up to my Promise, and it works great!Originally Posted by NightWing
(I did have to move it temporarily to another channel to flash it to 1.0f. The previous flash to 1.0d didn't required it to be moved). -
4X media has only recently come out, and there aren't a lot of varieties yet.Originally Posted by jacknjt
Someone has burned at 4X on the DRU-500A using Pioneer media.
A future firmware upgrade might help (as 1.0f did with 2X burning). -
I've not yet tried 4x media, but I can confirm the problems of attaching a DRU500 to the Promise RAID adapter. Burning was using up 100% of my P4 2.53! Switched it over to the IDE2 and it now uses NOTHING at all.....wierd.
Regards,
Rob -
Was that one of their regular Raid card or an Ultra. If stock Raid, deffently wont work. Requires two hard drives per cable only. No tape or DC/DVD will work right.
I think it was the regular RAID built into the motherboard.
Gigabyte 8IEXP:
"Promise PDC20276 RAID controller chip supports RAID 0,1"
"2 x ATA 133/100/66 Bus Master IDE for RAID 0 and RAID 1 ( only two HDDs could be used by RAID function )"
"2 x UDMA ATA 100/66 Bus Master IDE"
Regards,
Rob -
It better to keep the CD/DVD drive on the conventional IDE as other have found out. They use to put in a message in the instruction of put the non HD on the 1 & 2nd HD IO and your HD on their controller. Esp if you cant switch it off of RAID and into "normal" mode.
Tnks for the info. -
Purchased the printable surface Datawrite DVD-R x4 from www.blankdiscshop.co.uk, they are Ritek Gen 4 media (ADVDinfo).
Nero shows these discs as 4x speed.
I have burnt with DVD Decrypter at 4x no problems (16 min for a full disc)
They playback fine.
Drive used Sony DRU-500A firmware 1.0f -
I've got the same discs but with printed top.
They are indeed Ritek 4x...
Burned some of them succesfully at 4-speed, but others started to burn at 4-speed and then after 1 or 2 minutes decreased to 2-speed?
I'm using RecordNowMAX, Nero & DVD Decrypter to burn with my DRU500A, fw 1.0f.
-BK- -
I've only tried the one disc so far, I purchased 10 4x speed to test, and as I said DVD Decrypter burnt a full disc is 16 mins at 4x speed.
At the moment it's £9 for 10 2x and £16 for 10 4x, so until the price drops I'll stick to the 2x media.
If I have any problems with the 4x speed media I'll post here.
sony BDP-BX57 media
By Darkcast in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Apr 2011, 10:23 -
Sony DVD-R now bears "RITEKF1" media code!
By TooLFooL in forum MediaReplies: 12Last Post: 1st Jan 2011, 17:40 -
LightScribe Media with Sony Burner.
By dragonsbb16 in forum MediaReplies: 11Last Post: 14th Dec 2007, 21:44 -
Sony Media Manager for PSP
By GooseG in forum Portable VideoReplies: 0Last Post: 5th Dec 2007, 20:35 -
Memorex DVD-DL "RITEK S04" PLEASE UPDATE the media section.
By Crazyj32 in forum MediaReplies: 12Last Post: 13th Nov 2007, 03:28
