I have futurama season 2 region 2 (pal), i had plans to backup this fine collection on VCD's... But when i convert it to VCD via TMPGEnc i get some sort of ghost effects and the video is flickering (interlaced) but somehow these problems dont go away even when i try to use deinterlace on my video, i've tried odd fields, even fields etc. the video still comes out with scanlines and ghost effects, any suggestions on how i can solve this problem? thank you!
i had a similar problem with capturing and converting animation. the solution for me turned out to be converting to NTSC Film (23.976fps) and using inverse telecine but my source was NTSC (29.97fps), don't know what you can do when your source is PAL.
ty, i've heard from several anime rippers that all new anime wich is released in PAL Region 2 is converted from 23.976fps to 25fps this speed up cause a blended frame every 24th frame, also the intelaceing is causing the 24th frame to blend with the 23th and 25th frame wich makes a odd looking ghost effect, does anyone have any suggestion how i can deinterlace this source ?
Problem with deinterlace heeeeeeeelp!!!
By zikario507 in forum DVD RippingReplies: 21Last Post: 9th Aug 2009, 22:20 -
Tv Tuner (deinterlace) Problem
By harry29 in forum ComputerReplies: 1Last Post: 5th Mar 2009, 13:17 -
only 3 episodes of 6 will decrypt of futurama vol. 3 disc 1
By norm83 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2008, 19:20 -
Alparysoft Deinterlace for AVISynth problem
By _migz_ in forum Video ConversionReplies: 5Last Post: 3rd Aug 2007, 08:54 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 01:23
