Im trying to fit a 90 min movie on one cd but having no success ive tried all the diffrent KVCD templates and that all play jerkey like every 2min or so the movie plays jerky for about 15 seconds and i cant think of what to do to fit this movie on one cd any help appreciated
Results 1 to 9 of 9
you can just make a vcd with a a little bit lower bitrate than 1150 kbs. kvcd always works for me.
Don't discount using standard VCD encoding but using 90min discs!
Regards.Michael Tam
w: Morsels of Evidence -
VCDhelp has a guide using TMPEGnc to encode avi to VCD. u can change bitrate to squeeze on to 1 cd, if the movies not to long quality will still be good, ive used it to burn at least 50 i cd disc. lately though for some reason the mpegs are to long,dont know why using latest version
http://www.vcdhelp.com/forum/userguides/84759.php
apparently the latest version of TMPGenc has a bug in it, thats why your mpegs are ending up larger :POriginally Posted by isogonic
Yeah, a 90-min or larger-volume disc would answer without making the quality worse,
but it might not work on some dvd players... -
90 min discs themselves are reasonably well supported (though not universal). Anything more than 90 minutes and the compatibility starts dropping off quickly.
Regards.Michael Tam
My pioneer 636 will read the discs no problem, but only upto 88mins. After that the video just gets stuck in a loop.
Yeah, VCD non-standard multiplexing has gone wrong in TMPGEnc 2.59, so I'm glad I've got a couple spare older copies around to use
(now, to find one earlier than where the CG/animation matrix bug set in...)
As for it stuttering and going all jerky from time to time, it's likely a dvd player incompatibility thing i'm afraid. I've several vbr discs that play fine on mine but go completely haywire on a friend's machine. Some won't like bitrates above VCD standard (1x reading) or SVCD (2x, mine) and so when that occurs with VBR it'll be problematic. Some even appear to have problems with bitrates anything more than a few percent *below* the standard too (like my friend's machine). Annoying, but of course anything getting more than 80 minutes VCD on an 80 minute disc is completely non-standard and totally up to the manufacturer as to whether they include this completely extra service or not
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
best minimum size for a 1080p 90min movie
By renfr in forum Blu-ray RippingReplies: 8Last Post: 20th Jul 2011, 03:55 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 23:19 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
