Alright I have the DivX Codec installed along with the Nimo Codec Pack. I have a video file that isn't using the DivX Codec. For Audio it says "Morgan Steam Switcher" and for Video it says "Subtitle Mixer". I've tried doing the steps just like I would if it was DivX only in its final MPEG form the audio is junk. Its almost like it gets played backwards. Any help is appreciated. I've looked all over this site and may of missed something so let me know.
This may be a stupid question. It may not even be a cause to your problem, but when you installed Nimo, did you remember to remove the check for TFM Audio Filter v1.0 beta 7 before installing? I know there is an incompatibility there and you must take it out manually before hitting install. I don't know what kind of problems this may cause but if you did install this, you may have to get rid of that one if you need Morgan's Stream Switcher.....sorry if I wasn't any help!
Alright now it seems I just don't have the audio codec installed. I've tried what you said and I'm just not sure whats wrong. Is there possibly an audio codec that isn't bundled with the Nimo Codec pack or what? Please help me.
Thank you very much. Now I'm to this point.
It has found: WAVE_FORMAT_AC3
Made by "Dolby Laboratories"
It then said that it wasn't able to find a codec that could decompress it but could render sound through multiple filters. Any help there?
Note: It also calls it "AC3 from AVI XForm --> InterVideo Audio Decoder" -
hi soBe,
not sure if you've sorted this yet but do a search on google for "morgan stream switcher", and install the codec. i think this is used when a film is encoded with 2 audio tracks. e.g. english and german.
regards
john
MPEG4 subtitles
By miconba in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 00:11 -
Unknown encoder 'libx264'
By richiedood in forum Video ConversionReplies: 3Last Post: 19th Jul 2011, 11:53 -
unknown codec, mov container
By jlz901 in forum Video ConversionReplies: 4Last Post: 1st Apr 2009, 19:25 -
unknown file
By nicgrosso in forum ffmpegX general discussionReplies: 27Last Post: 7th Apr 2008, 14:20 -
Unknown checkbox in WinDV
By bemasher in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 17th Jun 2007, 21:05
