Regarding the Motion Search Precision setting in TMPGenc, is there enough of a difference in quality to justify the encoding time difference? I have done a few tests myself and I can't say that I saw much of a difference, but I'd be curious to hear other people's feedback.
Thanks.
The only reason to choose highest over high is if you absolutely must have the best and/or encode time isn't an issue for you.
The difference between high and highest is minor, and highest takes double the time of high. -
Just set it to "high quality (slow)" as you won't really see the difference between "high" and "highest".
Hope That Helps!!!
:P
Diamond Search for motion estimation
By bijo911 in forum ProgrammingReplies: 2Last Post: 10th May 2011, 19:26 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 11:40 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 16:30 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 08:30 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11
