help can't use tmpeg by itself after installing dvd2svcd
After I install dvd2svcd and use it with tmpeg to make svcd I can no longer use tmpeg by itself to fix a file. Whenever I load in the source into tmpeg it alway seem to stay connected to dvd2svcd output source no matter waht. I can no longer use the mpeg tool as well. Is there a way to unbind dvd2svcd from tmpeg. For example I wanted to rencode an mpeg that I had to make it vcd compliant but when I load it up in tmpeg it does get recognize. But when I press encode tmpeg will reference the dvd2svcd output file instead although dvd2svcd is not lauch. Please help
In the directory you run TMPGEnc from, there are two files you need to delete or rename. If you are in the program, exit. The files are:
1. CURRENTCFG.TPR
2. TMPGENC.CFG
That will prevent the program from knowning the last run config.
Good Luck
Tivo Homer
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 16:20 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 06:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 13:01 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 04:31
